Cantilever brake adjustment
Erik
198
My wife's approx 10 years old bike has cantiler brakes, which I tried to adjust.
They're Low profile according to Sheldon Brown Cantilever Geometry
After trying to adjust and reading that article I now realise that this is a formidable task.
Are there simple V-brakes with just two moving arms that will fit on the original bosses?
Sorry I can't help much here Erik. The problem is that the brake bosses are variable by manufacturer as well as type, Shimano's diffferent from Tektro's etc. The cantilever bosses may be different again, so measuring them will be the best way to check.
However, if you buy a V brake and at the same time the mounting bosses, these screw into the forks and are a standard thread. In alloy forks they can be very difficult to get out though, the threads often seized into place, so best to check that first.
Most V brakes have very generous brake pad vertical adjustment scope, so any of the simple arm type would probably be suitable.
I've also found the forum link below on the cantilever adapter mentioned on Sheldon's site, generally thumbs down, but some useful advice and links on alternatives. Scroll down the page for the advice:
cantilever change
Hope this is some help.
M
mk1
Hello Erik, I think you might have to replace the levers as well though, as the cantilever type levers will not pull enough cable through to work the V brakes properly.
No problem Martin, your advice is right and I'd forgotten to mention it.
Just as well you did.
