Can't get into the display settings help
nickk87
May 20, 2023
hello
I can't get into the settings and I can't find a way how
After I quickly press UP several times it asks for a 4 digit code
Does anyone know what to do?
5172151722
8,533
Usually one has to hold the up/down pads simultaniously for 5 -10 secs to enter the settings.
Is it a kit or an OEM bike with KT electronics ?
I suspect the latter as it is the user who decides if a kit is to be P/W protected.
If the latter first contact the vendor.
All you can do is try and input codes to see if it can let you enter and then onc ein disable the P/W.
Start with codes 111 - 999
Have you tried 000 & enter ?
Otherwise one has a lot of P/W's to try in numerical order.
8,533
As an aside though the label say's lcd8 it looks like it is miss labelled, the shape/design is LCD5.
8,533
If you have no luck then buy another KT display to use as it will not be P/W locked.
nickk87
May 20, 2023
The problem is that I don't know how to enter
Up and down is to change a number and off is to move between numbers
A long press turns off the display
Jaxter
104
23
i had this problem when getting my new bike a few weeks ago mine is a totally different display but it was a rapid double tap to get into menu, you never know give it a go
