Can you recommend a frame replacement ?
KirstinS
3,224
899
Brighton
My frame has died and I need to replace it. However, on one bikes have long stopped making the Pompetamine. Many months of ebay searching has been fruitless.
I'm not mechanically technical enough to know which other frames would do the job and take ALL my components
Can anyone help ? Appreciated it isn't ebike specific but I'm not on other bike forums and the depth of knowledge here is amazing
The spec sheet from the original invoice is below. All I've done is added front hub, suss post and a Brooks saddle and Marathon plus tires
Any help much appreciated. I'd like to stay with a steel frame if poss
Cheers
OnOne Pompetamine Alfine Comp
Shimano Deore M575 Disc Brake Set Without Rotor / Front BIKE BUILD [CBOOPOMPCOMP]
Shimano SM-MAR160PS Post To IS Adaptor Rear / 160mm
Shimano XT SMRT79 Centrelock Rotor / 160 mm BIKE BUILD [CBOOPOMPCOMP]
BSSHXTROTOR-160
BTSMGPM-120-HON
01 Racing JIS Square Taper Bottom Bracket / 103 mm / BSA Thread / Aluminium Cups
FSA Gimondi Track Crankset -Silver 48t / 170mm / 3/32 In
basket pic
OnOne Pompetamine Frame / Medium
Shimano Alfine Rapidfire Lever / Black / 8 Speed / Right Hand BIKE BUILD [CBOOPOMPCOMP]
Shimano Xt Black 36h On Mavic 36h Open Sport Silver
RR Alfine 36h Sil Mavic Open
WRSHIALF36HSILMAVOPN
OnOne CNC QR Seatclamp / 298 mm BIKE BUILD [CBOOPOMPCOMP]
Shimano Deore M575 Disc Brake Set Without Rotor / Rear BIKE BUILD [CBOOPOMPCOMP]
Shimano Alfine Fitting Kit BIKE BUILD [CBOOPOMPCOMP]
Shimano Alfine Sprocket with Chain Guide / 18t
FSA OS150 Road Stem / 90 mm / White / 6 degrees / 318 mm Clamp BIKE BUILD [CBOOPOMPCOMP]
OnOne Mary Handlebar / White / 318mm Clamp BIKE BUILD [CBOOPOMPCOMP]
OnOne Smoothie Light Headset / 11/8 / Black / External BIKE BUILD [CBOOPOMPCOMP][/quote]
Reactions: skippy_ian
