Can I upgrade to 36v for second battery
Alex Howe
Jun 10, 2016
Northampton
hello all, new here so please forgive my lack of knowledge.
My urban mover has front wheel DPL 36250.13 as the code for it I cannot find any specs on the web for it.
I am thinking of keeping an eye out fur a second battery. The current battery is 24v 9000 ah . If I do get one I am think done thing that may improve performance/ range. I get around 18 miles st the moment with some effort.
I have seen I can set the controller for 36v through the minshine setup "found on here"
Any advice would be appreciated and can anyone can point me to a battery that is a good price / long mah that would be great. I thought of fitting a larger battery to the pannier and it would be great if I could extend the range to 25- 30 miles. I expect I may need to make an adapter to connect the battery to the current bike connection to the controller.
Many thanks
Alan Quay
2,351
1,076
Devon
That motor looks like an 8fun/Bafang SWX to me. I have run the 24v model at 36v for years, no problem.
It will go quicker and have a little bit more power, but I don't think you'll get more range unless you get a bigger battery.
Sent from my HTC One_M8 using Tapatalk
Reactions: Alex Howe
8,533
A 2nd same spec battery will give you the range you need but you will have to carry both, a 36v 13 or 15ah battery will get you the extra mileage you want and possibly you may get up to 50 miles.
