Rather like headphone jacks, I think one or more of the wires has broken at the julet connector end. It was a glitchy connection - usually when I connect the cable and turn on the battery, the gear sensor pulses continuously with a little green light. When it didn't connect to the Windows PC, I flexed the connector plastic sheathing above the julet connector, and the green light would flash and stop. Would glitchy signals from the damaged connection, terminally confuse the controller? My bike is working fine, but the plan to increase amps from 15 to 20, has been thwarted. Now that I can solder ( ), I can simply order a new connector from China. When it arrives, I'll reinforce the flexing part of the julet connector with self-adhesive marine heat shrink, to reduce extreme flex and prevent that happening again.
