Help! Calling All Eletrician GURU. Brain Picking !! Turn Signals
SurRonny
19
Hey Guys,
Could someone please help me wire my turn signals up to my 12V battery, I have done a rough wire diagram with what I have thus far. I will buy you a coffee :D
NOTE = THESE INDICATORS DONT NEED A RELAY THEY ARE IN BUILT IN THE INDICATORS.
Any help will be greatly appreciated :D
Thank You :D
48847
8,838
Dave may prefer tea ?
SurRonny
19
Haha he can have what he likes, it worked a
I'm looking at a beeper relay to wire into the circuit.
The ones I've found online states it's for tungsten bulbs and NOT LED like I have.
Do you have any ideas why i couldn't use this one ?
Can you recommend one ?
I've been riding around tonight and making a tick tock noise while I'm waiting at lights; quite embarrassing
Flasher Beeper Relay, 2-Pin Motorcycle Motorbike Flasher Beeper Relay 6V-12V Blue Flasher Relay Indicator ABS Plastic Metal Blinker Relay Indicator Beeper Turn Signal Indicator Blinker https://amzn.eu/d/fjGQi1X
30,882
It uses the resistance of the tungsten filaments of the bulbs in its timer circuit, so won't work with an LED system. For that you'd need one that had an entirely independent flash frequency timer, but I don't know of one you can buy. Some newer cars will have them incorporated.
I893469365902345609348566
547
134
4,205
That won't work. Like the other one above, it's a flasher relay. SurRonny has flashing LEDs.
This one should work but you'd need two or one with diodes in series.
This type are cheaper but they only give out a constant tone.
48851
SurRonny
19
Could I put 2 intermittent buzzers one on the left & one on the right turn signal line ?
If so how would I wire it up ?
mxuteuk 6pcs DC 3-24V Wired Electronic Buzzer Alarm Sounder Speaker Intermittent Beep Tone SFM-27-II https://amzn.eu/d/7ecZGsX
48855
AndyBike
1,773
761
Pretty shoddy wiring going on here. Green one has a break in it and the others not even connected
;) :D
