Broken battery
kster68
11
Hi, I was wondering if any users had experience with my problem.
I was given an Ezee Torq earlier this week, and everything is working fine, but I also recieved an extra Nimh battery. Apparently this battery has never worked and was replaced foc by 50cycles when the bike was new. So, being an inquisitive sort, I took a look inside the battery. The visible problem seems to be a broken thermistor. How it came to be broken I don't know..maybe there is an underlying electrical fault.
Given that it seems unlikely that I will get another Nimh battery, would it be worth an attempt at salvaging this one?
30,844
Definitely worth a try. :)
The thermistor is a Semitec AT-4, part number: 103AT4 Shape 2. If not available, 103AT4 Shape 1 will also work. The main specification is R = 10k, B = 3435.
Semitec UK. Phone: 01606 871680, ATC Semitec - Products
They don't normally supply the public direct, but if you ask nicely, they may well send you a sample one free.
If there's any problem, a wide tolerance replacement is a Murata component from Radiospares, part number 188-5256, R = 10k, B= 3380
If there's still a difficulty or delay in getting a replacement, you can substitute with an ordinary 10k resistor which the eZee supplied charger will respond to ok. Doing this will mean no thermal cut-off of charge, but the charger has a secondary voltage based cut-off. That stresses the cells slightly more, but as it's an old battery, not too important.
You might find my "Torq Talk" website of interest.
kster68
11
Thanks for that flecc, I shall definitely be giving it a go.
The "TorqTalk" pages are great reading
Conal
228
different broken battery could help
I have an old battery with its only fault being the external fuse holder broken.
Flecc, could I open it and take this part out to post?
30,844
It's buried in between the cells stacks in some versions Conal, so might not be so easy. It's a small bead component with two thin wires, one to the centre connection of the charging socket. It doesn't have any polarity.
However, I don't think Kster68 will have a problem getting one, Semitec are usually happy to post one free as a sample, it's easier for them to do that than explain or argue about supplying one offs.
