Brand neutral charging in the future?
mark sutton
67
80
36
30,648
Makes sense since public charge points are needed in countries with high densities of e-bikes, like The Netherlands. It could also drive the provision of high speed charging capability in e-bikes.
It will be interesting to see what it does to voltages, it could drive all designs to a 36 volts standard for the sake of simplicity and low cost provision.
Trevormonty
1,135
564
17
NZ
All it needs is 2 or 3 big brands (Bosch, shimano, brose) to come up with standard and every body else will follow or miss out.
... What makes technical sense does not necessarily make commercial sense. Remember the difficulties in getting mobile phone manufacturers to agree to use the usb standard for charging, if a company has enough clout it will create its own standard, just to be different, and to force royalty payments from accessories manufacturers. Witness the iPhone...
What would make sense is to standardise on a specific 3 pin connector, and a standardised voltage. Say 48v. The battery packs would then need to be smart and adjust the voltage and current to suit it's needs. The circuitry required to do this would cost pence and weight only an once or two.
Although a fixed 41.5 voltage might appear suitable at present, there will almost certainly new chemistries at slightly different voltages and charging regimes.
30,648
True, but in e-bikes I don't think any company has enough clout. Even the Bosch clout is restricted to a couple of EU countries and by no means unopposed even in those.
It's most likely that this attempt will all come to nothing.
