Brakes
Rayrayy
Feb 2, 2021
Which hydraulic brakes are people using in there ebike builds ,I'm trying to find something that will take a brake sensor and a magnet ,my current brake lever is a akward shape so it won't work.
Fordulike
3,802
1,538
Mine has basic Tektro HDC-300 , which were easy enough to adapt with the sensor and magnet:
Reactions: PC2017
8,533
I dismantle the wuxing brake lever to retrieve the wired plunger/sensor unit with end connector, using 2 part epoxy I glue the sensor on to the brake body and then use an ali stop on the lever to activate the plunger.
Reactions: Fordulike
