Hi, looks like a nice forum!.
My Panda ebike conversion to my wife's bike has failed, and being unable to get any response from Panda ebikes I've finally tried to fix it myself.
The issue I had was that although the battery was fully charged and had 37V the LCD display on the handlebar shows empty battery and the motor would not power when pedalled or using walk mode.
I have fitted the Brainpower controller (model S866-C) and the LCD display S886 (thinking good to fit a pair), the good news is this now shows full battery on the S866 display and when I use the walk mode the front wheel drives correctly at about 4 mph (after using the intelligent wire to reverse direction).
My original kit was wired with no motor hall connections, just the three phase wires, so I have left it like this.
The problem is I am getting no motor drive when using the pedals (PAS), and I also have an error "E7 - Motor Failure" but the motor can run as in walk mode
Checks I have made are:
PAS - when pedalled forward I am getting output voltage switching between 0V and 4.6V 12 times per crank rev so this looks OK (constant 0V when back pedalling) - I measured on the blue wire of the 1:1 accelerator connector as attached image. - I believe this is the correct connection for the PAS - I have set P13 to 12 pulses per rev for the PAS output.
Throttle - I have no throttle but tried connecting the red wire to the white wire in the "Speed throttle" connection while control is in throttle mode, but again the motor will not run
Voltage is set to 36V as per my battery
I have checked the P10 setting to ensure PAS is displayed on the LCD, but tried it on throttle as well.
Hall sensors - my wheel (which is marked as a Swytch wheel) has hall sensor wires so I tried connecting them, but again no motor control
Brake wire - tried shorting this just in case a short was needed for no brakes, but display then shows brake symbol - and again no power to the wheel
It seems odd the motor will run in walk mode only - any ideas anyone? maybe the controller is no good?
See attached image
Many thanks
See attached image
Many thanks
