Bottom Bracket Size
PeterPi
87
41
I've had the TSDZ2 fitted to my twenty year old bike for three years, and now I'm looking to move the kit to a new bike. Nothing fancy, but the problem is making sure I buy a bike with the correct size Bottom Bracket. I see things like this "Sealed, 68x122.5mm Square taper ". I get the 66mm bit but what does the rest mean.
TIA
Peter
PeterPi
87
41
Thanks for that. I knew what the 68 meant, but the rest must be to do with the crank spindle, I suppose.
122.5 is as you say the crank axle length , one can buy sq taper BB's with various axle lengths.
Terol Jiang
11
yes, 68/73mm is the bottom bracket length (also called BB size) of the bike, i also know there is also have BB100MM and BB120MM in the market. usually the length of the crankset is about 170mm, so what 122.5mm means? Curious!!
Reactions: PeterPi
