so looks like you can cut power to the bms and just replace the cells but still not a easy job.
soundwave Esteemed Pedelecer May 23, 2015 16,699 6,428 Mar 8, 2021 #1 so looks like you can cut power to the bms and just replace the cells but still not a easy job. Reactions: GLJoe
D Deleted member 33385 Guest Mar 8, 2021 #2 soundwave said: so looks like you can cut power to the bms and just replace the cells but still not a easy job. Click to expand... Are you going to have a go at this? You mentioned range was down on your bike.
soundwave Esteemed Pedelecer May 23, 2015 16,699 6,428 Mar 8, 2021 #3 ill send it to jimmy as i have 2 batts 400 original from 2014l and a 500 i got few years later, you can fell the difference.
