Hi there. I have a 2017 Cube with the CX drive fitted. Had a warranty replacement on the motor cover from Bosch (chain is rubbing on original one). I need a tool to get the drive sprocket off so I can replace it. Is it this one I need?: https://www.e-bikeshop.co.uk/bosch-spider-lock-ring-tool-active-performance or is that for the previous model?
Is it likely I'll need repeated access behind that cover? e.g. is it worth me buying this tool or should I be looking for a loan from somewhere do you think?
