August 8, 20187 yr My bike came with a compact Bosch compact charger on paper it takes 7.5 hours to charge 500 battery. Are there any deals/after market chargers say either a standard or fast charger for a Bosch power tube 500 battery?
August 8, 20187 yr Not sure 100% about powertube (assuming same connector?) but "fast charge" (4Amp) chargers are available from a number of suppliers: https://www.bike-discount.de/en/buy/bosch-charger-active-performance-europe-218685 I'd strongly recommend investing in a genuine Bosch one rather than a 3rd party manufacturer. Maybe you can ebay your current 2Amp one or come to an agreement with your bike supplier (local bike shop?) on a swap if shorter charge time is important. I tend to just leave mine on overnight as the battery is never completely flat. I use a mechanical timer to turn off the plug after a number of hours charge which means it's topped up by the morning.
August 8, 20187 yr Bosch have just released 6A charger. Ideal for quick topup over lunch. Where time isn't an issue, its best to use your slower 2A charger as its better for battery.
August 8, 20187 yr Author Not sure 100% about powertube (assuming same connector?) but "fast charge" (4Amp) chargers are available from a number of suppliers: https://www.bike-discount.de/en/buy/bosch-charger-active-performance-europe-218685 I'd strongly recommend investing in a genuine Bosch one rather than a 3rd party manufacturer. Maybe you can ebay your current 2Amp one or come to an agreement with your bike supplier (local bike shop?) on a swap if shorter charge time is important. I tend to just leave mine on overnight as the battery is never completely flat. I use a mechanical timer to turn off the plug after a number of hours charge which means it's topped up by the morning. Good idea about timer on plug thanks.
August 8, 20187 yr Author Bosch have just released 6A charger. Ideal for quick topup over lunch. Where time isn't an issue, its best to use your slower 2A charger as its better for battery. Bet that's not cheap, didn't realise quick charging affects battery life, thanks for reply.
August 8, 20187 yr I'd strongly recommend investing in a genuine Bosch one rather than a 3rd party manufacturer. What 3rd party Bosch compatible chargers are there? I tend to just leave mine on overnight as the battery is never completely flat. I use a mechanical timer to turn off the plug after a number of hours charge which means it's topped up by the morning. Is there any need for this? the Bosch system automatically shuts off charging when finished. Also, are you certain that leaving it plugged in but not on isn't doing something unwanted such as draining power back through the now off charger?
August 10, 20187 yr Author Turns out I used s 1amp shaving adaptor which the charger blew. Why they still supply uk with 2 pin chargers is a joke. Evans said they normally supply a visitor adaptor but have brought all the local supplies of them and have run out. I now have a visitor adaptor and the battery is charging. Small thing, but when you pay the price of an ebike you expect none of these issues or a waste of an afternoon sorting this out.
August 10, 20187 yr Turns out I used s 1amp shaving adaptor which the charger blew. Why they still supply uk with 2 pin chargers is a joke. Quite simply because you don't want to be playing with 13a sockets in a w/c or bathroom, which is why we still have low amp 2 pin plugs/adapters.
August 10, 20187 yr Turns out I used s 1amp shaving adaptor which the charger blew. Why they still supply uk with 2 pin chargers is a joke. Evans said they normally supply a visitor adaptor but have brought all the local supplies of them and have run out. I now have a visitor adaptor and the battery is charging. Small thing, but when you pay the price of an ebike you expect none of these issues or a waste of an afternoon sorting this out. Evans keep on - illegally in the UK - supplying Bosch ebikes with two-pin mains plugs. The charger must by law have a three-pin plug which plugs directly into a standard household wall socket. My guess is Evans can get Euro-spec bikes and/or chargers for a few quid less, which means more profit for them. It's not the most serious offence, but given they are consistently offending it would be worth reporting them to your local Trading Standards department.
August 10, 20187 yr Author Food for thought Evans keep on - illegally in the UK - supplying Bosch ebikes with two-pin mains plugs. The charger must by law have a three-pin plug which plugs directly into a standard household wall socket. My guess is Evans can get Euro-spec bikes and/or chargers for a few quid less, which means more profit for them. It's not the most serious offence, but given they are consistently offending it would be worth reporting them to your local Trading Standards department. Food for thought, surprised a company as big as evans would do something like that.
August 10, 20187 yr Food for thought Food for thought, surprised a company as big as evans would do something like that. Yours is one of several posts on here we've had from people who have been supplied a two-pin charger by Evans. They are taking the wotsit, and will continue to do so until they get a fine or two which will exceed the extra profit they make from supplying illegal chargers.
August 10, 20187 yr Author Yours is one of several posts on here we've had from people who have been supplied a two-pin charger by Evans. They are taking the wotsit, and will continue to do so until they get a fine or two which will exceed the extra profit they make from supplying illegal chargers. Will email them about my experience and see what happens.
August 10, 20187 yr Expect a brush off. What you need to do is email someone to whom Evans will listen.
August 10, 20187 yr Every electrical appliance purchased in the UK, needs to be supplied with a 3 pin plug as standard. Evans are certainly braking the law. My Trek purchased from a Trek dealer, was supplied with a 2 pin plug, but the shop was aware of this Law and fitted a Visitor plug, that they buy locally for £1 each. Evans seem to cut so many corners. Ignorance is not an acceptable reason to break the Law.
August 11, 20187 yr Author Your local Trading Standards Office is the place to complain to. Are they going to give me a discount in evans or any money back, unlikely.
August 11, 20187 yr I must have got lucky, my Trek supplied by Evans has a proper UK plug on the 4A charger.
August 25, 20187 yr I bought a couple of Cube Reaction ebikes from Cycle Gear Halifax last month, both annoyingly had euro plugs. Just received my Cube Stereo Action Team from Rutland today and thankfully it has a UK plug in the box, will be using that to charge all 3 bikes now!
August 27, 20187 yr Chainreaction also supplied a 2-pin but I am going to buy a UK spec lead: https://www.bike-discount.de/en/buy/bosch-power-cable-for-charger-uk-520771 4euro.... Incidentally it looks the same as my TV power cable, check if you have one spare and if its the correct amperage rating.
