Bosch Active Line Plus Bike... Carrera Crossfuse General Questions....
Heinzja
41
15
Carrera Crossfuse E-Bike Women (2018) (36V) Purion Display (one piece/Display not removable) Power button
Motor: Bosch Active Line Plus BOU350 Crank motor
Battery: Bosch Power Pack 400 (On Frame)
(Like my Avatar..!)
I need some help to understand my bike ( I inherited it..) Please correct my observations/explanations if I am wrong. Thank you in advance for your help. This bike is new to me; I got it because I am currently a bit disabled due to an accident, and another frame model would not be suitable for me at the moment.
To switch the bike on: Press the Battery Test button (which is also the Battery On button), then press the power button on the Purion Display.
There is no other way to switch the bike on.
The (frame) battery pack has a lock that is mechanical only; the lock does not have an electrical connection and does not switch the battery on/off.
The crank motor has a cover for the wiring. The cable plugs go into the controller, which is built into the motor. The controller is not removable (only by Bosch service?).
The blind plugs for accessories cover additional light (12V) and what else?
There are cables available with the right plug for the light, but the light has to be software-activated via the micro USB service port (so the light can be switched on/off via the Purion Display?).
The Purion has no reset button/hole. Can a reset be done by a key press combination when the display is on, or is there another method?
For bike insurance: The serial number is on the frame above the motor and is displayed in two rows.
Which is the serial number: the top row (7 numbers), the bottom row (5 numbers), or is the number the total length of both rows (12 numbers)?
Thank you again for your help.
