i dont have the old motor anymore as got a cx motor last year but between the 2 batts must be about 10.000 miles and the 500w is still ok capacity wise so they do last.
m8s shimno bike has 1000 charge cycles on his warranty so it is different to bosch warranty but there still the same cells and no way that will do a 1000 charge cycles as he uses a dongle as well but has 2 batts.
the old motor did still work but the transfer gear needed replacing and a new set of bearings and it was as good as new.
Genuine Bosch service / repair kit for the Bosch Gen 2 ebike motor. This part is available for you to buy and fit yourself.
www.ebikemotorcentre.com
so as long as you service it with new bearings ect it should last decades but the new smart frame batts from bosch wont work on any of the older motors so will make these thing obsolete.
