Hi,
I'm wondering if someone might be able to point me in the right direction with a problem e-bike I have. Just to clarify I'm a complete novice and have absolutely no idea what I'm doing (honesty is always the best policy lol)
Recently my brother passed away and I ended up inheriting a Qulbix Raptor Q140 e-bike.
The bike had been stood for a long time (1.5 years) and so the first problem was a totally flat battery, when I turned the key, nothing happened at all, the bike was dead. I got around this by pulling the battery appart (it's dozens of 18650 batteries) and charging them individually and putting the battery back together.
This worked as in the bike can now be turned on at least. BUT....
When I twist the throttle nothing happens, I think the bike has shut down into like a protection mode.
On the bike's LCD screen I have a !BMS! warning symbol at the top.
Finally on the BMS circuit board there are 3 little red lights, which I'm assuming is a warning something is wrong.
The circuit board has 7 slots in total and I am using 5 of them as in the picture attached. If I move all the connectors 1 to the left, then the 3 red lights vanish and the bike turns on OK, but again I get the BMS warning error and the throttle does not respond.
Does anyone have any ideas about what I should try next ?
Thank you very much
Thank you very much
