BMS has extra sense wires, B+ and DS-
andrew_sal
Oct 28, 2020
This BMS I bought seems to have two extra sense wires labeled B+ and DS-.
B+ is shorted to BC13 so I would imagine that B+ connects to the battery +, but if they are shorted what is the point of having it?
DS- is not shorted to BC0, it's shorted to P- so I have no idea what I'm supposed to do with this wire. What does DS stand for?
Thanks for your help, there seems to be no information out there.
8,743
A link to the BMS ?
3,994
Looks like the first picture doesn't have it but the 5th does.
If you look at the other pictures in the listing, you'll see DS- also marked P-, and if you follow the track from DS-, you can see that it's connected directly to P-. You therefore have a fixed positive and switched negative going to flying leads. You can connect whatever you want to them - anything like lights that doesn't require too much power or nothing at all, but my guess is that they're for a battery charge state indicator if you want one or a USB module.
andrew_sal
Oct 28, 2020
So I assume I can just unplug them and not use them?
