bms battery ecitypower chargers.blue is live wire?
rpurchon
55
just got a 36v 20ah battery from bms.
the battery charger comes with a short lead with kettle style plug for charging.
i decided to lenghten the charge cable and alter the connectors on the battery.
i fitted a female deans on battery and male on charger.
pluged in to charge and sparks.a few blown fuses later, cover off charger.
turns out blue is + and red -,
fortunatly there a chunky diode in charger to protect reverse polarity.
hope this will be of help to others and save a bit of head scrathing.
the fuse are, fast 10a 250v.
richard
You're not yje first to find out that! In fact it seems to be more or less standard on Chinese chargers - not just the Ecitypower ones. With Chinese stuff, you should always check with a meter. Pretend you're colour blind.
