Blowing Fuses
mygrumpy
55
Sutton, Surrey
Hi.When i lift the drive whell of the ground the motor go OK.when under load the Fuse blows.this a Trike.4 batteries wired in Series & Parallel.Changed it from belt to chain drive,Ratio 38/11=3.4 Ratio,Seems to have a lot of speed with the back wheel of the ground,do you think the Ratio is to high or to low.Thank you for any help given.John
fcurran
394
Bath
www.powabyke.com
Check the wires inside the battery by the back of the fuse holder. It can occasionally happen on a Powabyke and its usually as a result of the wires fusing together under load.
mygrumpy
55
Sutton, Surrey
Hi Fcurran.Not a powerbyke.It`s a E-Trike,batterys not in a box.Do you need to run the Earth wire from the controller & Battery to the frame.John
fcurran
394
Bath
www.powabyke.com
?? Not sure?!
Perhaps putting a higher voltage fuse in the battery may do the trick, however be aware this may put more strain on the circuit board.
Regards
FrankC
