I have the Bionx 350 on a 2006 Marin mountain bike. The crankset is a 42/ 34/ 24 with the rear 8 speed cassette 11- 32. Riding the bike last year I was impressed by the power and hill climbing ability but knew there was more top end possible. With this set up I found that my cadence was uncomfortable when driving in the top gear at 34 kph (20 mph) so I knew the bike needed higher gears. ( I have found that most pedelectrics need to be used at lower cadence than my road bike......ie. road bike cadence is 88 but pedelec is around 65 for me.....anyone else notice this??)
Anyway I took the top speed limit off the bike over the winter and I am now sure that I will need higher gears. Here are the results.....In Kph (mult. by .6 to get mph )
Lifting back end off the ground using throttle (with speed restriction on ) the motor cuts out between 33 and 34 kph (speed goes higher before slowing down and motor cuts in again at 33 )
Unrestricted throttle takes wheel up to 56 kph and holds at that speed with throttle activated. ( no load speed)
Results using pedelec on flat was 42 kph but my cadence was crazy ( I am sure it was over 100)
The way the bike is geared now the cadence feels good at 31 kph in top gear.
There is a crankset made by the same company (48 / 38 / 28 ) that will fit on this bike. So top gear would be 48 and 11 compared with the 42 and 11 used now. Any ideas about this upgrade?
I know from the few speed runs I did today that overcoming the air resistance is the key. The amount of energy needed to get 10kph more was astounding ( very exponential !!! )
So this is my progress so far in search of the elusive 50 kph ( 30 mph) !!!!
I am thinking maybe 45 kph with the addition of a new crankset......and probably lots of spandex for the air resistance.....oh my , not a good visual, I am on the large size!!!
