Bike cuts out
Pappaboy
Chester Le Street
Hi, hoping someone can help me please.
I bought a batribike Granite Pro 2nd hand.
Used to belong to an old gent who sadly passed away.
The bike is in excellent condition however having not been used for a while the battery was no good.
I bought a brand new battery from Batribike, fitted it and everything works as it should in the garage, however, riding it is a different matter
The electric will turn itself off before I get to end of street, everything goes off, the screen goes blank etc etc.
You can then switch it back on and the same thing happens every few feet.
If you put it on the side stand and lift the back wheel off the ground and put into throttle mode it just goes forever. No cut out.
Any ideas ?
Faulty battery or charger, or you didn’t charge it properly. You need a meter to measure the battery's voltage after you charge it.That will guide you to the source of your problem.
Pappaboy
Chester Le Street
Voltage of battery seems fine.
It will go forever when not under load but cuts out when rider is on.
I'm wondering if it could be worn brushes in the hub setting off safety cut off when the current is getting high
If you want to solve your problem, do as I say.
spanos
250
64
Can you post the measurements from the battery after a full charge and the charger output
Plus, maybe my poor googling ,but that bike has a brushless motor I think ? How many wires ? 2 is brushed and 3 is brushless
spanos
250
64
Edit - crossed with d8veh. The forum can totally help but need to work with exacts. Your fault description is common but has several possible causes. We need those readings to start the diagnosis
8,533
Forum members have helped out many with battery cut out issues and battery repairs but we need to see the listed voltages you are seeing.
Measure the voltage output of your charger and as requested the voltage of your battery after it has been charged, otherwise we can't help.
Reactions: Wheel-E
Pappaboy
Chester Le Street
I
I will take both to work this week and post the readings here.
Thank you for input , as you can probably tell I'm a total newbie to electric bikes.
Pappaboy
Chester Le Street
Hi again,
Had battery and charger both checked by the electrician at work.
Both are working fine.
Charger putting out 36v and I'm sure he said battery was putting out 36v
Does that sound right.
What do I need to do now ?
Thank you.
5,786
Charger should be 42v.
Reactions: chris_n
8,533
We need to know exactly the voltage readings and not "sure he said this or that ".
For a fiver buy a digital volt meter off ebay or Maplins and carry out simple checks your self.
A 36v li-ion battery has a nominal 36v rating, when fully charged it should register 41.5 - 42v. Your charger should be out putting 42v as AK has mentioned.
A definite charger out put voltage, 36v not good needs to read 42v & a battery out put reading 41.4v - 42v anything less will indicate a battery not fully charged or one out of balance.
Out of balance means cells of unequal voltage.
Usually when the power switches off it is due to a bad battery contact or often low voltage cut off (LVC).
Lvc is set within the batteries BMS board and the controller which can be lower . At a 36v reading the battery voltage will sag due to the load being applied/asked of it from the controller, it will dip 2 or 3 volts lower and at 33 or 34v may bring the lvc in to play.
Thank you.
They're both knackered if that's true, in which case you need to replace both of them to solve your problem.
chris_n
737
440
Niedeau, Austria
Not necessarily true, the battery could be fine if it had a chance to charge up fully. If the charger is only putting out 36V the battery has no chance of being any higher.
spanos
250
64
Neal and others are bang on here
We need exacts. And to be honest , you need a multimeter ! Anywhere from a fiver to 30 absolute maximum. A Ebikers best friend, trust me
Not hard to use. Stick red probe on positive terminal and black on negative. Read number on screen
Even if you get that the wrong way round you’ll just get an inverse reading ie -42v instead of +42v
If there is an issue with your battery your going to need it for the next steps
Plus, and forgive this cynical old sod, but I’m not entirely convinced your electrician actually bothered to check.......maybe they did but hmmm
Reactions: Nealh
