BEWO 350W 48V Mid Drive for sale
haggis
36
15
Fife
Hello all, I have for sale a Bewo 350W 48V mid drive for sale.
It has done somewhere between 300 and 700 miles - I wish I had checked before disconnecting,either way not very much,I think nearer the 300.
Apart from the whole kit I made a point of purchasing a spare
a) Controller
b)LCD Display
All unused
The last kit I noticed on ebay was £355 obviously without the extras.
Must be worth £250 at least!
Offers
Derek
haggis
36
15
Fife
Bewo I believe is meant to be a bit like an 8fun crank drive with the controller outwith the motor which I think is good, especially if you have a spare.Much easier for repair if required. It also has metal planetary gears as opposed to plastic I am informed and according to a Greek chap elsewhere on the forum they are the bees knees!
5,786
They have been around for a while (since 2013?) but are not mainstream, Woosh used them at one time IIRC. I also like the external controller and it will run at either 36V or 48V and it has a 48 tooth chainring.
haggis
36
15
Fife
Good you brought that up,I went for the 44T chain ring ,plenty fast and better for hills.
8,517
Didn't Woosh use the TCM cd is this the same unit ?
How about bb fitting does it fit a std 68mm shell or even a 73mm.
Is it a stand alone 48v unit or is it dual 36/48v as I have seen it talked about as both.
5,786
Yes it is the same. From memory (a year ago?) reading the posts on ES by a Greek engineer who mounted one I think he had to file the inside of his BB a little. Runs at either 36 or 48 V, the controller is the only change.
Edit: Tianjin Bewo Technology Co I think it was abbreviated to Tianjin Company Motor
Found the link
http://www.ittsb.eu/forum/index.php?topic=963.0
Reactions: trex
haggis
36
15
Fife
It's a standard 68mm bottom bracket, certainly no filing required by me and I only ever ran it at 48V.
haggis
36
15
Fife
This one has been designed for 48V. I believe some designed for 36volt are sometimes used by individuals at higher voltages.
haggis
36
15
Fife
Found the link
According to the General Manager at Bewo they make a 36v 250w. 36volt 350 watt and a 48V 350W all with different controllers.
