January 25, 20215 yr What display you prefer with your Bafang motor? I was thinking about getting 500c for it's compact size and integrated buttons which reduces wire clutter.
January 25, 20215 yr I only have experience with the 500C and I really like it. When I first opened the box, it was like wtf! is that it.... But it is very clear in use and allows me to keep my Garmin 530 on the stem. The PAS buttons work very well, even with gloves on.
January 25, 20215 yr The 750c is my current fav in the middle of the bars and low profile and the excess cables hide underneath
January 26, 20215 yr Author Another vote for the 500c from me I only have experience with the 500C and I really like it. When I first opened the box, it was like wtf! is that it.... But it is very clear in use and allows me to keep my Garmin 530 on the stem. The PAS buttons work very well, even with gloves on. Does hydraulic brake sensors and throttle work with 500c btw? Edited January 26, 20215 yr by mt247
January 26, 20215 yr Does hydraulic brake sensors and throttle work with 500c btw? Yes they do. The hydraulic cut offs are part of the 1 to 4 way plugs coming off the loom, so completely separate from the display. You do get the little brake activated symbol though and the throttle works a treat
March 18, 20215 yr Are these just plug and play ? I’ve just bought a bike that uses a Bafang G020 motor but it only has LED dots for PAS and battery level. If I could just unplug that and plug another type of display/controller in its place I’d be one happy bunny.
March 18, 20215 yr Depends if your led is analogue or digital, lcd's are all digital. I’m going to embarrass Myself and ask how I can check ? It’s a 2021 bike if that helps.
March 19, 20215 yr Are these just plug and play ? I’ve just bought a bike that uses a Bafang G020 motor but it only has LED dots for PAS and battery level. If I could just unplug that and plug another type of display/controller in its place I’d be one happy bunny. Remember, the guy from Mirider said that he had upgraded the standard electrical system to CANbus, which would prevent that. Some of what he said didn't ring true, and I think that it would be worth checking to see if that's the case. You'd have to pull out your motor controller and show us all the wires attached to it if you wanted to change anything.
