Hi all
So in the middle of summer my bbs02 loosened up and started hitting the frame when accelerating, i did the temp zip tie fix which was fine, but now as a permanent solution im thinking of going for the lekkie one nut.
The lekkie four 42 torque wrench head is expensive at around £45 is this absolutely necessary or is there a cheaper head available from someone else.
