Up till now if you wanted to alter the settings on your BBS02 (or BBSHD) you had to get a cable and laptop along with software but not any more.
Dillenger have introduced a self contained programming box called the Switcheroonie and they recently sent me one to try out.
Its a great bit of kit and has 6 different modes available.
They are---
250W with no throttle and 17Mph speed limit
250W with throttle and 17Mph speed limit.
500W with throttle and no speed limit.
750W with throttle and no speed limit.
Unlimited with throttle and no speed limit.
User set limits which allows you to save the current motor settings.
The throttle is available even when the PAS is set to 0.
I have used this for a couple of weeks now and it works a treat.
Start with the bikes battery disconnected.
Simply turn it on then unplug your lcd display and plug the box in its place then connect your bikes battery
It will read the current settings and then you use the up/down arrows to choose the settings you require.
Press the "tick" button and the program will be loaded and when its finished it will tell you to disconnect the box.
Reconnect the lcd and away you go.
http://dillengerelectricbikes.co.uk/spares/bafang-8fun/switcheroonie.html
They are---
