I've bought a Bafang BBS01B to fit a 73mm bb the round nut is fitted but there is only two thread showing could this be 68mm bb
Just make sure it is well tightened and check it now and then.I've bought a Bafang BBS01B to fit a 73mm bb the round nut is fitted but there is only two thread showing could this be 68mm bb
Mine look the same I well Loctite it thank youJust make sure it is well tightened and check it now and then.
Make sure you tighten it with the correct tool. Don't banjax it by using mole grips etc.Mine look the same I well Loctite it thank you
