BBS01 cutting out when changing assist level
Steve J H
82
17
ROMFORD
Hi All
BBS01 cuts out when reducing assist from level 3 to 2, strangely this only seems to happen once per ride. Screen goes blank with loss of assistance for approx 3 seconds then returns to normal with level 2 as selected. Everything works as expected for the rest of the ride regardless of duration. Have checked connections all ok, could it be some kind of programming issue?. Programming is stock as delivered with five levels of assist selected, I have changed assist to 9 levels and will see what happens on tomorrow's ride. This is a recent conversion and only covered 120 miles, no problem for the first 60 miles. Has anyone else experienced this issue or know of a remedy?
Steve
3,993
You must have a short or faulty connection somewhere. If the battery cut off the supply to the screen, it wouldn't come back on.
Reactions: Steve J H
Steve J H
82
17
ROMFORD
Yes I agree the battery supply must be constant, just don't understand why it only happens when assist is reduced from 3 to 2. No other changes of assist will induce the fault, nor will it reoccur during the same ride. I will recheck connections and cables for damage.​
Many thanks​
3,993
The logical things to check are anything that might be disturbed when you go for the shifter or when the shifter's in that position.
