I have a 20 mile each way commute from Guildford to Teddington and in recent years I’ve generally been driving half way and then cycling the rest. Thanks to a very useful demonstration last year (thanks KudosDave and LEBC Tom) I found it would be perfectly possible to use an ebike for the entire journey, freeing up our one car so it can stay home with my wife and the kids.
The bike needed to be a bit more upright than my old roadie, a bit more comfortable overall but still quick (I need to get home to help put the kids to bed!). I chose to do a conversion of a Cube SL Road Pro flat bar road bike – lightweight, with plenty of tyre clearance and hydraulic disc brakes. I used a BBS01 250W from Eclipse Bikes for the electric assist, and I wanted to keep the entire thing stealthy.
Key points:
So how does she perform? So far, very well indeed. In lower assist levels she rides very naturally with assistance right throughout the cadence range but not too much strain on the drivetrain (can happily change gears without using the motor cutoff switch on a brake lever). For her first run I cycled from Guildford to Cranleigh and back using assist level 2 – still quick enough to overtake club cyclists out riding in the Surrey hills.
Both trips combined used 4.4Ah of battery, so on the (crude) assumption of average voltage during the run being 38.5V the journey consumed 169Wh of energy, or 7.1Wh per mile. I was certainly putting in a reasonable bit of effort myself too. Distance and speed information taken from Runkeeper GPS tracking.
So how about commuting? Absolutely cracking. The first week's figures are here (there are two routes, A and B):
So the journey's taking a smidgeon over an hour, which is the same as my previous drive / cycle approach. Using assist 3 I'm averaging maybe 11-12Wh per mile and 19.5mph, and with assist 2 about 7Wh per mile and 18.5mph (but using more of my own energy).
The bike is working out very well. It is comfortable for distance, fast, and practical to use day in day out. Whether I'll continue every day or take a day each week in the car I don't know, but this week I'm continuing cycling every day. It definitely puts the miles on - it's already up to 378 miles!
Some further photos of the bike this evening to finish
Michael
Key points:
- 10s4p pack welded up from Panasonic NCR18650PF 2,900 mAh cells held in a pack behind the saddle (with clothes, pump, tools etc.) charged to 41V
- BBS01 programmed to allow full cadence in any assist level, and to provide full power under PAS only (both changes from the normal controller operation)
- Set up for 5 assist levels
- Tyres changed from Kojak slicks to Vittoria Voyager Hyper ultra-fast 40mm touring/commuting tyres
- Wiring to provide a 7V supply to the handlebars for my lights (not yet fitted)
- No throttle
- Hydraulic brake cut-off sensors
- Bars shortened to 595mm (from 660)
- Ergon GP3 grips added
Michael
