Hi
Please can any one tell me is the updated controller the same in the 250 watt and the 350watt and hopefully even the 500w you can all guess my thinking I do not want supersonic speeds just thinking about a steady cruise speed just a few questions
what is max safe current limit on 250w
on the colour display have seen 465watts peak in short bursts most of the time it is around 200w I do pedal honest can this be adjusted
is there a profile that any one has used lead and laptop at the ready most sites show for 48v us spec
the gearing is ok 52t on the front thanks to the hammer a block of wood and clamps the alfine8 is 18 t at the rear it is happy in 7th gear cadence around 65 to 75 per min the wind resistance shows in 8th and the chain line is good and it has got a spring tensioner
not short of battery power as it is huge 990watt it is also far to heavy for the original cloth bag supplied the straps did not last 30mins hence the big box
thanks peter
thanks peter
