Battery Weight vs Range... a dilemma
So, one of my e-bikes is powered by a 350w Bafang MaxDrive motor. It came with a 374Wh 10.4 Ah Samsung 29E Pinky celled battery pack which, then, was a respectable if mediocre cell... I bought a second at the same time which the dealer was keen to clear at £150... that was IIRC 2019?
Anyway, one pack typically gets me 25-28 miles, given the terrain I ride and the way I ride. On the odd occasion I've take the second battery in a back-pack to extend my range.
Both batteries after 5 years are still good, given my storage, alternating usage, and care regime, but I suspect they're likely coming to end of life...
So my question is this:
If you take a common format, let's say Hailong (which I can easily change to), what is the weight penalty of one 20Ah battery against say a smaller capacity (lets say 13/14Ah, of which I'd need two)?. Cost is largely irrelevant... it's weight that bothers me. Obvs, a 20Ah Hailong is going to use higher capacity/better cells that a 13/14Ah one, but at what weight increase given a typical ride for me is increasingly becoming 30-40+ miles? The spare in a back-pack, when I need it, is increasingly becoming an uncomfortable burden/necessity... I'd rather not take a back-pack.
So boiling it down to basics, how heavy is a 20Ah Hailong vs a 13/14Ah one given the cells needed to provide that capacity?
The other reason I'm asking is that a better/higher capacity cell would allow a higher current cell to rinse the motor, which the Pinkies just aren't capable of doing.
What would you choose/do?
....... I'd rather not take a back-pack........
What you need is a good pannier rack.
I have just come back from a hilly ride this morning. (76 Km). I was carrying a total of 32 Ah at 36V volt battery paralleled and weighing nearly 8 kilo. No problem with a good touring rack and keep the weight low. Also plenty of room for snacks, rain gear, tool etc.
My 19.2Ah battery made with LG MH1 cells weighs 3.6kg, if that helps. I chose the largest my BBS01B kit seller had available, because I needed maximum possible range with high level of assistance. I've learned since of the other advantages of a large capacity battery for hill climbling, trailer haul hill climbing, longevity because individual cells are less stressed in a larger capacity pack than a smaller one discharging the same current etc. My bike and I don't care about weight, so I might even consider using something like this longer lived 3,000 charge cycle 30Ah 11kg lifepo4, if I was certain my 36V BBS01B controller or DPC18 display wouldn't throw a fit at it's fully charged 43.8V - I presently have a spare controller, so could risk finding out, if I can find a very cheap compatible display. Perhaps a stolen DPC18 display will turn up on ebay, going mega cheap because it's been cut off some other dude's Bafang mid-drive conversion.
https://vi.aliexpress.com/item/1005003686955227.html
https://robocraftstore.com/product/36v-30ah-12s5p-lifepo4-rechargeable-battery/
https://manlybattery.com/product-item/36v-30ah-lifepo4-battery/
Edited by guerney
20Ah Hailong - on short trips you get the benefits of higher voltage (more power) so after 30-40 miles it would only be half empty and you've got that reserve if you need it. I bet the weight penalty is less than 1kg between a 20Ah Hailong and a 13/14 Ah Hailong - you don't want to be hauling spare batteries around.
You can calculate the weight of any battery from the number of cells. The capacity doesn't mean anything and doesn't necessarily affect weight. 18650 cells weigh about 50g each, so 2kg for 40 cells 2.5kg for 50 and 3kg for 60. Add about 1kg for the case, BMs and receiver. A 21700 cell weighs about 66g, so adjust your calculation accordingly.
By way of example, a 50 cell 36v battery with the highest capacity 18650 cells will have 5 x 3.6ah capacity = 18ah, and the cell-pack will weigh 2.5kg. A 50 cell pack with 2500mah cells will weigh the same, but only have 12.5ah capacity.
When you buy a battery, you have to take all these characteristics into consideration along with the price.
I'm impressed with [mention=33660]guerney[/mention]'s 3.6kg for 19.2Ah. My 28Ah (13Ah + 15Ah) cheap solar batteries add up to 7kg.
I agree with lose the backpack.
I did worry that I'd been palmed off with a fake LG MH-1 celled battery, but they weigh 49g each, and the plastic case doesn't weigh much, neither do the small BMS and nickel strips - if they're rerwraps, the underlying cells are pretty good fakos whatever they are. I haven't included the weight of the mount, but it's light. Or perhaps my cheapo digital luggage scale is rubbish.
https://lygte-info.dk/review/batteries2012/LG%2018650%20MH1%203200mAh%20%28Cyan%29%20UK.html
Tested my cheapo digital luggage scale with cast iron weights: 0.5kg weighed 0.54kg, 1.2kg weighed 1.31kg... and I reweighed my battery - it's even lighter now! :eek: The plastic case is pretty thin... whatever, it gets me 43 miles at highest level of asistance over mixed terrain with the controller limited to 15A and 100% "Keep current".... and more importantly, hasn't exploded into a house consuming fireball yet. I'll weigh it again when fully charged lol, it's 36V at the mo.
Edited by guerney
I hear you. But this bike is for good weather touring on Norfolk back roads. I do have a rack on another e-bike for commuting, but don't want a rack, panniers or mudguards etc - i.e. excess weight - on this one for the specific purpose this particular bike is being used for... it's dry weather, all day/weekend touring.
My bike and I don't care about weight...
I do care about weight on this e-bike, for this purpose of general touring (it's the bike in my avatar). My other e-bikes I have for general use and those are geared and work well for practicality so weight is less of an issue for me there.
...so after 30-40 miles it would only be half empty and you've got that reserve if you need it. I bet the weight penalty is less than 1kg between a 20Ah Hailong and a 13/14 Ah Hailong - you don't want to be hauling spare batteries around.
That was exactly my thought too... my rides on this bike for this purpose can only get longer. I'm getting fed-up with the burden of carrying a spare battery.
Surely the density (i.e. individual cell weight) would be more on a higher capacity cell, wouldn't it? Have I got that wrong?
That really is what I want to do. A backpack is cumbersome and becoming a real pain. The bike is otherwise "lightweight" (relatively) and powerful (comparatively), and it's a real joy to ride when unincumbered around the Norfolk wilderness... where none of the practicalities of a commuter or general-purpose e-bike with racks, panniers, mudguards, lights and all that other essential paraphernalia are needed that tend to bog you down and hold you back.
I'm definitely erring towards a much bigger battery...
Not 29E cells if 10.4ah/374wh (10s4p) as the figures don't add up.
Cells must have been 26F as 29E would give 11.6 ah (10s4p).
Besides that battery weight will be the same.
One 20ah battery will be approx. 1.25kg - 1.4kg lighter then a pair of 10.4 ah.
Edited by Nealh
18650 = 47/ 48g typically.
21700 = 68/69g typically .
20ah would likely be Sam 50E or LG M50 21700's so 40 cells, 2,76kg.
10.4ah would both be 40 cells as well, 7.68kg.
Typically one will be near 4.8 kg lighter, a little more weight is saved as only one case , one BMS , less wiring and less nickel interconnectors used.
Edited by Nealh
No. 21700 is bigger than 18650, so weighs more and has more capacity. All cells of the same size weigh approx the same, regardless of capacity.
[ATTACH type="full" alt="20240404_214955[1].jpg"]57102[/ATTACH]
[ATTACH type="full" alt="20240404_215004[1].jpg"]57103[/ATTACH]
not got any left now but those fake pink wrapper ones are like 28-32g
Edited by soundwave
Any genuine 18650 cell will be in the area of 46g - 48g no matter the mah rating, likewise a 21700 /68g, 20700/58- 62g and 20650/55-58g.
According to my cheapo digital luggage scale, my battery weighed:
3.49kg
https://www.pedelecs.co.uk/forum/threads/new-project-started.46218/post-700688
... in January this year. Now it appears to weigh 3.28kg... so either my scale is rubbish (very likely), or the cells are genuine fako rewraps. 50 LG MH1 x 49g = 2450g, leaving either 1040g or 830g for the case, wires, nickel strips, fish paper, solder, fiberglass wire lagging, switch and BMS. Bit late now to demand a refund, on the other hand the battery performs well, as far as I can tell. Maybe I should buy one of those ebike battery load tester things, or simply wait till the battery pack dies then weigh the case and a cell after disassembly.
https://www.amazon.co.uk/Vastarry-Electronic-Capacity-Monitoring-Constant/dp/B0B7N7RB3Q
Edited by guerney
Ah, I stand corrected... 26F then,,, it's been 4 years since I opened one of the packs. 18650 pinkies though. I guess one battery of higher (double) capacity will logically be the best route to take.
Just weighed my Hailong 48v 20Ah 960Wh battery - 4.8kg
My wife's Wisper 36V 700 Wh (19.5 Ah ?) battery, I think has LG cells - 3.5 kg
I think getting a 20Ah battery that weighs 3.5 kg is not much extra weight (how much does your existing 374Wh battery weigh ?) for
1) a lot more range
2) higher voltages / more power on shorter journeys
Pink is one of Sam's often used cell wrap 22F, 26F, 26H, 26J, 29E, 30Q & 35E are all pinkies and most popularly used battery cells.
I carried both a 11ah (22F) & 13ah (26F) for about 100 miles range though I used a rear rack top bag when I had the oxydrive kit with the superb Bafang CST hub and swapped them over when lvc was hit .
The batteries only lasted me two years as I would drain them to lvc all the time to get the max range ( batteries imv are for using and there is always something better to use next time ). The cells as expected lost capacity so range dropped quite a bit and would only get me some 60 -65 miles , I still have most of the cells now some 8 /9 years on . They are used in torches some reconfigured for two 12s packs for other uses and the 22F's are still complete as a 36v softpackwhich also has another use where current draw or mileage isn't needed.
Later on I used a PF 14.5ah on the down tube and a PF 23.2ah in the rear rack bag , handling was good when riding but a bit cumbersome if pushing or manhandling the bike sometimes. This became my longer range set up and I could return home with 40% remaining and never hit LVC.
Old cell packs still have uses or the cells as individual cells do, one reason why I don't take them to a recycling centre until absolutely knackered. One can use them as mentioned for torches, reconfigure for smaller packs for power tools or low voltage gadgets where current demand has little effect on their usage.
If one had enough cells of the same mah then they could be made up into a power bank if one had solar or a stand alone panel in the garden to charge it with or wanted to make use of cheap electric rates with some tariffs.
One could easily use old cells for a larger portable power bank to run a pc /laptop, kettle or lighting during a rare power outage or as a regular supply for a pc etc,etc.
1) a lot more range
Going 48v over 36v as seen does add quite a bit more weight , depending where the weight is placed is the issue. When I carried my 23.2ah 48v battery over the rear wheel the rack was fitted as far forward and as low as I could get it over the wheel/mudguard to make handling much better, in use the handling was very good but it was sometimes a bit cumbersome when trying to manouvre off the bike.
I found the best use for 48v larger batteries was on much longer day rides of 100miles or so, one still had plenty of power for hills without hitting lvc.
1) a lot more range
I don't know what the existing batteries weigh, but labouring under the misapprehension that a larger capacity battery might weigh a notable amount more, I didn't really want to permanently saddle this bike with that extra weight for my shorter/sub-25-mile rides. But 25-mile rides are quite restrictive in Norfolk, which is why I'll cart my bike in my van to explore new areas and take both batteries.
But you raise a good point/benefit I hadn't considered: Maintaining a higher voltage level for longer even on those shorter runs. Sweet.
I'd be surprised if it's more than 1.5 kg different for a 20Ah 36V battery - they weigh around 3.5kg
So both of those give exactly same (and nicely rounded) value of 200Wh/kg, 5kg/kWh
