Battery safety cut out switch
skutter
12
Electrics + British weather + rock salt = risk of equipment failure.
Does anyone make a handlebar mounted device to cut power should throttles/switches become stuck on?
Stephen-Gately
23
On your handlebars you'll find 2 sticky-out things, probably silver in colour. These are commonly referred to as brake levers. Pull them in an emergency and you'll stop.
30,846
Many e-bikes do have cut-outs integrated into the brake levers, and these are mandatory in Europe with their pedelec bikes. The controller has to have the facility to connect these though.
john
531
Manchester
It's a good idea to have a switch to isolate the battery which is independent of the controller. With a brushed controller failure, power can become permanently routed to the motor.
Phil the drill
395
TR9
I had that happen to me on an old Powabyke! Going down a steep hill so didn't notice 'til I tried to slow down and stop at the bottom :eek: (the Powabyke didn't have brake lever motor cut outs....). The fun was brief, but the memory lingers on.....:D
Phil
