I have 2 Ebikes and a 17.5Ah battery, originally I bought a separate mount so that I could swap the battery between bikes. However I since decided to get a second battery that could be used as a spare and allow me to take friends out on it.
I searched high and low and eventually found a battery on Ali Express that looks the same. After 3 months of waiting for it to arrive from China, it appears to be a totally different mount to the picture.
I am not sending it back as I am just going around in circles. So question?
How hard would it be to buy an empty battery case and mount and transfer the cells and BMS into the new case?
Both are Hailong, both 17.5Ah and the case is quite similar in size
If there is any major risk then its probably not worth doing as both batteries are new and work fine. But if it is easy then it is worth doing
Any advice?
Any advice?
