Hi, I've been pointed here from the CTC forum website.
I'd appreciate some advice from members who understand the workings of an electric bike. I have added 3 kits to various bikes I own - 2 are rear hub motors with big downtube batteries supplied by the excellent Woosh; the other is the Cytronex C1 kit fitted to a lightweight bike and is also excellent for its intended purpose, which is a bit of help now and again. I have thought about using the rear wheel off one of the MTBs with a smaller (lighter) battery but don't really understand the details of how the motor and battery are connected. I know that there is some sort of controller which "sorts" the voltage/wattage/amperage but what exactly does it do and, given the motor wheel's configuration, what should I be looking for in a battery and controller. I'm asking this because the bikes I would play around with are in Europe and, post-Brexit, I think I would have to source the components from outside the UK. The motor wheel has an Aikema 85 hub, which I like a lot but which Woosh no longer supply. It is 36v, rated at 250w and has the controller built into the battery holder (looking at the Aikema website I'm guessing that it is the KZQW22-HL1 model) but the only item I can understand is that it has a 16A "limit current", already far outside my knowledge.
If I wanted to use the wheel what should I look for in a battery, controller and display? I'll be grateful for any help.
JVB
JVB
