Yes could give them a try. But like I said I have to remove cover each time to remove the battery as I can’t charge it when on moped. Would they stay stuck. I have tried strong Velcro but that came off after 3 try’s of removing battery
should work if you use enough of them.
Well on Amazon they charge another £5 on top for postage. So looked on eBay and found some heavy duty ones so ordered 2 packs And it’s free PPit locks together like velcro but a lot stronger i have a 4 way adaptor on the wall with 4 phone charges in it and can pull it off the wall and put it back on with a hard push.
on the back it says if you use 4 on a pic frame and 4 on the wall it can hold 7.2kg
Well is it really stealing them. It’s a bit like someone going into Poundland and stealing 1 x £1 item and believe me I have seen office workers and even high up people steal from Poundland. I mean FFS if you gonna steal make sure it’s a top class jewellers make it worth it thenthey sell them in the supermarkets so easy to nick them lol
they cant get plod involved unless it is worth more than 250 quid but my mum nicks them in her mobility scooter esp the batts there a fkn rip off these days esp rechargeable ones.Well is it really stealing them. It’s a bit like someone going into Poundland and stealing 1 x £1 item and believe me I have seen office workers and even high up people steal from Poundland. I mean FFS if you gonna steal make sure it’s a top class jewellers make it worth it then
WhereBilly shock horror we have a new erider member, have you noticed .
Blimey. Ask him what that weird plug is for! Was it for a kettle?Where
oh you mean plas man. Just seen his post
I cant do that as I live in a 2 story flat, and moped is kept in my shed. which don't have electricityWhy not simply make an extension power lead, so that you do not have to remove the rubber mat for each and every charge?
Whatever you do otherwise, will get worn and damaged eventually.....
regards
Andy
Im lost what do you meanBlimey. Ask him what that weird plug is for! Was it for a kettle?
Well I cant make eyelets, I think its a special tool for making those. I had also thought about strapping top and bottom end of mat with like you said a bungee cord. as you can buy 12 pack for only £6.75 30,40 & 60CMEyelets in the corners, bungee cords with hooks underneath.
Mat might need reinforcement at the eyelets.
But will try these command strips 1st
Its ok when I have my feet on top of battery riding moped, But I just feel the mat may blow off when i leave moped. whilst shopping. I could remove it and lock it under seat. But battery is showing then.
thanks for all the ideas guys most appreciated
