Shoreham-by-Sea (Sussex) mostly flat but wind exposed and hills for leisure trips.Hi Perseus, Where are you based and what type of riding will you be doing (commuting, leisure, off road etc)?
Just out of interest, what Kalkhoff did you ride? I have a crank drive with battery below the seat and it's neither out of balance or at all sluggish..For the balance and ridability what is the best location for the battery? I've only tried a Kalkhoff and it seemed back heavy (w/o a pannier load). It did not ride very well and felt sluggish.
Weird. I kind of get the opposite impression from my Pro Connect and it's pretty much the same kind of ride as the one you pictured. I do have two panniers but tend to ride with one with a couple of bits and bobs in it. Sometimes I fill it up with some shopping and for some reason it doesn't really feel that side heavyIt felt like a pannier load of book (heavy) on my ordinary bike as I cycled to the library for renewals. Rather a weight to respond on a long ride or certainly slightly offroad on footpaths. Far from ideal for short shopping trips as well. I will still need to get an ebike though as I am getting on. Throttle start needed or hub gears becuase of the excessive other traffic.
It felt sluggish, pedal only. OK with the power assists. Different though.Just out of interest, what Kalkhoff did you ride? I have a crank drive with battery below the seat and it's neither out of balance or at all sluggish..
If you were using it with the power off it would have felt heavy and sluggish alright. But why would you? If you don’t want to use the power why buy a pedelec? Did you put it in full power and try going uphill as fast as you could? The feeling of having bionic legs is worth the money just for that.It felt sluggish, pedal only. OK with the power assists. Different though.
