Battery lights showing RED why?
John F
435
55
Just checked the lights on my battery after fully charging it. (green light on charger)
Battery has 6 lights, 4 are green but the other 2 are red. WHY?
Its had about 70 charges from new, with no apparent issues regarding range
Geebee
1,256
227
Australia
Its not just showing all the lights including the lowest 2 in red? one of my batteries shows 1 red and 4 green when full, if the red comes on alone it means its flat.
John F
435
55
6 lights in a row. Middle 4 show green outside 2 show red.
It's just that you would expect all greens?
As the battery discharges, the lights go out one by one starting with the greens, so: 4 greens 2 reds, 3 greens 2 reds,......, 2 reds, 1 red, time to pedal.
peerjay56
745
201
Nr Ingleton, N. Yorkshire
Is all greens the normal condition after charging? How discharged was the battery beforehand?
trex
7,703
2,671
Andy @ Woosh is not in this afternoon so I can't confirm but if I remember correctly, the there are 6 LEDs at the back of the CD batteries, they are symetrical. The two outside LEDs are red, they correspond to about 15% capacity left, the next two (which are LED 2 and LED 5 from left to right) correspond to about 15% to 40% and the middle two (LED 3 and LED 4) 40% to 100%. It would be simpler if they have 5 LEDs red + 4 greens. The voltage is better displayed on the LCD.
John F
435
55
That would be useful to have confirmed. You are correct on the LED layout, however I fail to see how your description helps me! Logically they should be all green surely?
The LCD said full up.
John F
435
55
So that could be my situation? i.e. there is(are) always 1 or 2 red?
trex
7,703
2,671
yes, the outer LEDs are always red LEDs. They are not multicoloured. The two middle LEDs go out first.
John F
435
55
Well that would be reassuring, however d8veh seems to say the outer red lights give some indication of charge? I'm confused
John F
435
55
Errm, so why did you charge it?
Philip you have misread my slightly ambiguous statement. More importantly why won't you be in York on Sunday for the big day or are going to check it out somewhere else?
