Hi everyone....got my first conversion kit last week.a bafang 750w and 48v battery...im over the moon with it....the freedom it gives me is brilliant....time away from the house and peace and quiet away from the kids for a few hours is priceless....
Having a problem with the battery...when I built the kit up the battery was showing 86% on 500c display....I rode away on it and put it on to charge when it showed around 64%....the charge only took 4.5 hours....when I checked the display it was 53.6v and 100% after the first charge....that was all good was using the bike as normal for about 30 miles getting used to everything....2nd charge I done yesterday and it took about the same time 4.5 hours to charge....so turned the display on it was reading 53.6 again....happy days I said all charged for work the next day....then the voltage started to drop to 53.5 then got lower as I stood there....53.4 53.3 down to 53.1 in the space of 10 mins.then I turned everything off....gave it ten minutes or so and tried it again....got 53.6 initially then started to drop again as before....
Next step i check the battery with multimeter and got a reading of 00.0...strange I thought.....put battery back on bike and run the motor and it ran ok with rear wheel lifted....woke this morning turned it on and the same 53.6 on start up then dropping slowly....
One thing to add is i was tidying the cables up and the red and black wires did touch... battery voltage was normal after that no dropping....just after the second charge it this has started.....hopefully I've explained this right...
Any help or feedback much appreciated
Thanks for looking....
