Battery Info.Please
Del Arthur
46
Just been out on a first test run, on the new (second hand) Batribike Granite, first impressions are quite favourable......only went about 1 mile, and while in motion the battery indicator dropped to about half full.....as soon as I stopped, it went back to showing full......my question is, is this normal ?
30,602
Yes, as soon as you open the throttle or apply full power in any way, the indicator changes from showing battery content to showing the rate of current drain. Stop using power and it shows the battery content again.
Reactions: Del Arthur
Del Arthur
46
Del Arthur
46
Ah, thanks for that.....so hopefully the battery is in good order......I think a longer journey is called for..........
30,602
Yes, no problem. This is fundamentally because batteries are chemical devices, they don't store electricity, they just convert it into a chemical state. But we can't measure that chemical state so we try to measure content using the output voltage which is a very inaccurate way.
wheeliepete
2,047
757
Devon
We refer to this as voltage sag and it does tend to increase as the battery ages. You will find that as it depletes and the battery voltage decreases, the bike may cut out until the voltage recovers. Using lower power levels and minimal throttle, if you have one, you will suffer this effect less and get better range.
Del Arthur
46
Thanks for that, hoping to go further next trip out, but it does seem that the battery is o.k.....according to Batribike, the batteries for this bike are no longer available, but there are some on Ebay, of the same voltage and amperage (36v 10Ah) if I need to change it......the guy I bought it from assured me that the battery was in good order, but of course you never know......
