hi guys,
my first post here and i'm looking for some help/advice.
I've been using a 1000W ebike kit with 48V13.5ah battery for my 11 mile commute to work - when i arrive i charge battery for my cycle home as there's 20% left. I've covered almost 2000 miles and the battery seems to be draining a little faster which i expected, just maybe not this soon.
I've read charging to 80 or 90% can extend battery life, does anyone know if it sounds too late to start doing this? And, with having only 20% left when i arrive , would a partial charge do more harm than good as it would be below 20% if not fully charge to begin with?
Perhaps i just a bigger battery altogether,
any suggestions would be great,
thanks ,
Ian.
According to what I have understood from some good links on the net, the upper 10% and the lower 30% are considered by a good charging system to not to be used.
The charger voltage should stop at the upper limit, and the battery safety electronics will stop at the lower limit.
You can charge your battery and measure the voltage across the battery when the LED (generally) goes green to say that charging is stopped.
The voltage you should should be seeing is 4.2 volts x the number of cells or cell groups. For 48 volt nominal Li-ion batteryies, that should be 13 in series. I reckon that to be 54.6 volts max for safety.
My battery for example is a nominal 36 volt and I see exactly 42 volts when charging is finished (Not a micro volt more) and the battery is fully charged, so mine is 10 cells in series.
How many are in parallel for the 10 groups, depends on the maximum current needed.
I have two chargers and both show exactly the same "end voltage" of 42 volts.
But I have read here of chargers that "over charge" which will significantly impact the life of a battery. Not seen any myself, but I try always to err on the side of quality and safety.....
What some here do not believe is that leaving a charger connected for periods AFTER full charge is achieved, can be very detrimental to the batteries life. You also see it on any products that use such batteries such as laptops! People forget to only partially charge the battery, and remove it from the laptop,when running on the mains. They are surprised when the battery dies early!!
So I modified a very cheap electro mechanical time switch, so when the set time is reached, it not only completely removes mains power to the charger, it also switches itself off completely.
All you need to know is how long a charge takes approximately and set that on the timer!
Its a tiny bit "hit and miss", but still better than nothing!
I use such things whenever I charge ANY type of battery.....
It allowed my last e-bike to achieve over 6 years of usage, and the bike was given away still fully working, and no noticeable drop in capacity.
Though of course some loss was probably there, but I never ever needed to test very exactly! It still did the miles I needed each day....
Over 30,000 Kms in all....
I keep telling myself that I should build an electronic switch, that senses when the battery is fully charged EXACTLY and remove the mains completely and not reapplying it!
I did it for a LA charger for my caravan some years ago and that works (still very) well, and its quite simple to do really!!
That battery is 15 years old and still going, but is LA not Li-ion!! Different chemistry!!
If I can help further, just ask.
Andy
