Hello.
On my Boss conversion, the battery (48V) is connected to the bike's electrics by plugging two plastic connectors together - see picture below.
Can I buy a short extension lead with the same connectors, so that I can mount the battery in a 'better' position? Currently it sits behind the saddle, which makes the back of the bike very heavy (unbalanced), so I was thinking of
mounting it on a front rack instead. This would need another 18 inches or so of battery lead with those connectors.
Advice welcomed.
A
Done a bit of googling and it seems they are 'Anderson' connectors.
Found this 1m length which seems to have the right ends already..
Is voltage drop a problem with ebike batterys and length of cables?
http://www.ebay.co.uk/itm/1M-x-25-MM2-BATTERY-CABLE-ANDERSON-PLUGS-SB-175A-BATTERY-JUMP-CONNECTOR-LEAD-/141248907340?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item20e317484c
Advice welcomed.
A
