Battery Capacity Measures
JohnInStockie
1,048
Stockport, SK7
I was looking at the energy density of the A123 batteries, and was quite impressed until I actually calculated their energy density vs other NiMH types. So I am not sure if I have done it correctly.
The way I calculated this was :-
The Voltage x Amps to give me the energy capacity in Wh
divided by
Pi x height x Radius squared to give me the volume in cubic centimeters.
Doing this gave me:-
A123's h = .652cm, r = .26, vol = .138 cm3, v = 3.3, ah = 2.3, ED therefore = 54.8 WH/cm3
Yuasa's h = .57cm, r = .31, vol = .172 cm3, v = 1.2, ah = 9, ED therefore = 62.8 WH/cm3
Am I missing something?
John
Ian
1,333
Leicester LE4, UK.
John, it seems you used the diameter instead of radiius and your dimensions in cm are a tenth of what they should be (1cm=10mm), eg the height of the A123 should be 6.52cm or 65.2mm. That doesn't alter the fact that the NiMh has a superior energy density by volume, my calculations giving 0.69 & 0.78 Wh/cm3 for the A123 & Yuasa cells.
By weight the A123 fares better with 108 Wh/kg as oposed to 67 Wh/kg for the NiMh.
JohnInStockie
1,048
Stockport, SK7
Thanks Ian. Does this mean that Nimh are best for energy density then? I am thinking if/when I recell, I would like to have it recelled with the greatest possible energy density.
Ian
1,333
Leicester LE4, UK.
It seems NiMh have the best energy density by volume but not by weight.
NiMh cells are by far the easiest to use from a diy perspective though, especially as you have the option of using a reasonably priced pre-assembled cell pack from powacycle for which a purpose made charger is available.
It's best to use the original Giant thermistor and charger with the Powacycle pack when recelling though, since the Powacycle charger is a fairly low quality one without a discharge function.
Recelling details on my site.
