Batteries
Peter Ball
85
20
87
Hi, Being fairly new to lecky bikes, we have two Woosh Zephyr - Bs which have a 250w motor and a 36 - 10Ah battery. Should I have gone for ones with 36V - 15Am one or would this have made a huge amount of difference?
We are pensioners and intend taking them away and using them whilst on holidays with our motorhome, I've converted a trailer and fitted a bike stand to carry them.
Thanks for any advice.
Peter.
Tomtomato
388
196
The 15 Ah one would give you 50% more range. Also, when the battery life starts decreasing after many charges/discharges, then 10 Ah will become a bit short in term of range.
In term of weight, the 15 Ah will be heavier than the 10 Ah one, but it shouldn't make much difference on an already very heavy ebike.
Therefore, I would go for the biggest battery possible, that you can afford.
trex
7,703
2,671
Peter's bike is not heavy (about 21kg). The question is how much range do you need? 10AH will give you about 30 miles. Aging will lose about 2 miles per annum.
Tomtomato
388
196
I guess you meant not heavy for an electric bike!
When he runs out of power a few miles from home, he may think he is riding a heavy bike!
Personally, I would purchase the largest battery possible, as running out of power (or worrying about it all the time) is not fun.
Peter Ball
85
20
87
Hi, Thanks for the information, as you probably know the battery sits inside the frame. Eventually, would it be possible to buy a 15Ah replacement I think Woosh only do the 10? I've had a quick trawl round the internet but haven't come across any which look the same
5,786
From the Woosh Zephyr B page...
"Spare battery:
ultra-light high discharge rate 36V 10AH Samsung cell.
1.5kgs
£235 including courier cost."
trex
7,703
2,671
Peter, woosh will have 14AH in frame battery in August I think.
SteveRuss
566
265
57
Bristol, Uk
Peter.
Obviously a bigger battery is preferable if you are wanting to travel greater distances but also as whilst the battery is draining, it's supplying an increasingly lower voltage and hence a lower assistance level.
Reactions: Tomtomato
RoadieRoger
726
200
For replacement cost , range and weight , I think the optimum is 11Ah . Obviously it does depend on use/route . After 6 years of riding Ebikes and 12 years of retirement and a battery re-cell , this is my opinion for what it`s worth .
5,786
12.8 Ah here (16 Ah of Lipo) that gives me about 70 km range: 15 to the station, 40 km return and a bit of safety margin to prevent range anxiety.
I think that if I had the money I would have a 17 Ah HL Li-Ion battery and nothing less. Using it a 1C would mean less sag on our steep hills.
D8ve
2,142
1,294
Bristol
Spare battery at under £250, for 10ah doubles your range or is a new power pack in a few years time. If the old one deteriorates.
The alternative 14ah battery will give more range or allow less human effort as you age. Enjoy the retirement until you need to replace and keep the money safe. Don't buy a new battery until you need too.
