Batribike sigma how to chanfe from pedal assust to throttle
Patriciah
Jun 9, 2020
Hello considering buying a secondhand batribike sigma but found it a little skittish on start up, I am pretty nervous at riding the best of times.
Is there a way of changing it from pedal assist to a throttle grip type, or something in between.
Sorry if it's been covered before, but would really appreciate some help
Patricia
8,843
Can you explain skittish with the PAS ?
8,843
Yes front will drive can be like that, do you start off in PAS level one ?
Also try starting off with the brake slightly pulled on to control the motor wheel spin until it is comfortably under way.
