Batribike Granite LCD Charger / Batt Prob
nookey
Aug 12, 2011
Hi
I have a Batribike Granite LCD which uses a 36v 10ah battery
The charger is 36v 2a which only takes just over 2hrs too charge the battery from flat
Is this right
nookey
Synthman
417
Oxford
No, on a 2a charger it should be taking well over 4 hours to fully charge from flat. Either the battery is coming to the end of its life, and losing capacity or there is an issue with the charger causing it to stop charging too early.
Have you got a multimeter to measure the battery voltage with? If so charge the battery and post back saying what the voltage reading is from the connector pins on the battery. Should be around 41-42v fully charged, and around 34v empty.
nookey
Aug 12, 2011
Bike is new
Hi
The bike is only 7 weeks old from new
Only 2 hours to charge the battery from the first day i had it
I have just got a new battery from take charge bike and batribike
This unit is only taking 2.5 hours too charge from flat
I think the charger maybe duff
What do you think
Synthman
417
Oxford
How many miles can the bike do on one charge?
I had a problem with charger a while ago, it was cutting out too early. I had to keep turning it off and on to get it charging.
If you could measure the battery output after a full charge it would be easier to work out if the charger is faulty. Can you get access to another charger to try?
nookey
Aug 12, 2011
Hi
Old battery was around 10 miles
New battery dont know as yet not had a chance to test it
I will test both batts with a multi meter
What should they read fully charged
Maybe i can get take charge bike to get me a new charger from batribike
nookey
Synthman
417
Oxford
Yes, that is correct. It might be slightly higher when it comes straight off the charger, it drops after the battery has been standing for a while.
