Basics of a Lithium-ion Battery Charger
Biker44
134
A video almost impossible to follow.
Whereas this video -
- makes the same thing look ridiculously easy.
At least in theory - in practise, the once highly regarded GOPHERT CPS-3205II (Portable Adjustable AC to DC Variable Switching Power Supply AC DC Converter 110V/220V switchable Great for Provide Constant Voltage or Current Supply) has vanished from reputable suppliers (Amazon and so forth) - "Currently unavailable. We don't know when or if this item will be back in stock."
All is not lost - there are many other suppliers of the same thing. However, there's a hitch. This power-supply ("charger") does 0volts to 30 volts and a 36volt lithium battery probably needs up to 50volts.
So, suppose I wanted to manually charge such a ("Silver Fish style" in an ali Extruded tube) battery, how would I do it?
Biker44
134
Use the 60v version!
Ha! Thankyou! I've found it! Just £55 from a box-shifter-brings it to my door! Why are no other Bikers beating a path to this mans door?
There's even a 120 volt version for only five squid more.60683
4,238
There's even a 120 volt version for only five squid more.View attachment 60683
I recently bought this one (60v 5A), which was £61 all said and done. They added pre-paid tax at the time of order. Note that the max power is the same for the different versions, so if you get more maximum volts, you get less maximum current:
Reactions: Biker44
Biker44
134
Thanks for the tip - are we to understand that the picture above (from our friendly deliver-to-your-door box-shifter) is pushing the bounds of crediblity? That would be sad, they're usually quite good.
However, the safe charging rate of our e-cycle batteries is probably only around 2 amps (that's the limit of what our chargers currently deliver).
Someone tried to sell me a three amp charger (at £100!) claiming "it would be faster" - without any kind of explanation, I'm afraid I politely declined.
The new power supply is still easily capable of blowing up my batteries (in the concrete lined passage-way where I plan to use it) - I will have to be super careful.
But I will (briefly) double check what you've said about maximum current at maximum voltage before sanity returns and report back.
4,238
You don't have to check anything. The power supply itself will only allow the maximum current shown in the listing, which is 10A for the 30v one, 5A for the 60v one and 3A for the 120v one.
Reactions: Biker44
thelarkbox
1,677
524
oxon
Sure you know but with a Bench PSU Always start with power turned down and tune up the voltage/current Never Down..
Biker44
134
I'm a neophyte. I'm depending on you guys to bring me up to speed and leading me to the sun-lit highlands.
4,238
You set the current to what you want with the coarse then fine adjustment, then you set the voltage the same way. When you're happy with that, you connect the device you want powered or charged, then you press the green button to activate the power.
Reactions: Biker44
Biker44
134
Whoopee - XLR connector arrived - did I see that two of the three pins can/should be connected together?
If that's right, I can use my nice long length of 2-core rather than cutting up a decent 3-core extension lead.
4,238
No pins should be connected together. Only the outer pins are used.
Reactions: Biker44
thelarkbox
1,677
524
oxon
imho Even if 2x pins are ajoined on the receiving socket, dont mirror that on the input, it will limit the safe use of the charger to just the one single battery..
**Double and triple check polarity ;)
XLR connectors are fairly easy to solder but the larger sized male pins can be a bit of a heatsink and soak up enough heat to melt the supporting plastic they are mounted in. If no spare female socket is available to use as a 'holder/steady' (the battery is not a good idea imho) a good dollop of blu-tak can be shoved in place around the pins to add further support for the hot melty pins. And give the socket a good few minutes to cool before you do a big tug test on the wires.
Reactions: Biker44
Biker44
134
Ah - thankyou. I can go ahead wiring it up with the tidy length of two-core cable I have. I wasn't sure what sellers-information I'd seen provided on a flea-bay (?) link.
Biker44
134
Several useful tips from you there, thankyou.
The decent length of two core cable I have (from a mains vacuum cleaner?) could be good for up to 2000 watts, roughly 8 amps at mains voltage.
It should handle 2 amps at 45 volts (nominal 36volt battery) with no trouble.
I note what you say about checking polarity! The 50 volt power supply comes with its own "multi-meter" style male connectors ending in pretty tiny insulated crocodile clips. Instead of which, I will use ring terminals on the supply that came with a lead with an inline fuse. I think its about 10 amp protection.
Fatgadget
49
7
A dedicated lithium battery charger is not simply a cv/cc PSU. It wont for example commence charging a battery should it sense <2V per cell bundle. And when it finishes the balancing bit of the cells at full charge,it terminates power .
Reactions: Biker44 and jarnold
Biker44
134
Is there a useful tip in there? Can it be that I could easily have recovered the 2.5 year old Bosch 400 Battery on my 2017 c7+ Gazelle with the dinky toy people here helped me find? Obviously can't do it now.
