I recently bought a kit to convert my old mountain bike.
It came with :-
Bafang g020 rear hub motor as a complete wheel ( no model number on the motor)
KT15A motor controller
KT LCD3 Display
and all the required cables but absolutely nothing in the way of instructions.
After purchase of some longer machine screws and a rear rack to mount a battery it all fitted together and mostly worked.
I thought it might need a bit of tuning to get things quite right and that's when I found the details required setting up the KT-LCD3 were hard to find. Lots of information on how to go thru the settup on YouTube but less on what to punch in. The Bafang website told me the gearing ratio and number of magnets to set the P1 parameter but not the wheel speed pulse rate.
It would seem to be a common conversion combination.
Trying some setup parameter combinations actually took the level of working percentage way down
Is there somewhere I haven't yet found that is good source for the info required.
Still trying to reduce the list of things I don't yet know I need to know...
It came with :-
KT LCD3 Display
