April 28, 20187 yr I’m thinking about converting my mountain bike (Giant Trance). I’m currently approximately 100kg’s and I like the idea of some assistance getting up the hills. The bike is used predominantly off road. Will a 250W Bafang mid drive have enough power, or will I be disappointed and regret not going for 500 or 750, or even the BBSHD? The price and lower weight of the bbs01 is appealing (also road legal), but is it buy cheap buy twice?
April 28, 20187 yr in my experience, the BBS01B is much more reliable then BBS02 (compared to both A and B versions). The BBS01B is my preferred CD kit. This is because you are much less likely to climb hills in the wrong gear with the BBS01 like you can with the BBS02. The controller for both have the same ability to dissipate heat but the current is much less on the legal BBS01, the probability of failure is much less.
April 28, 20187 yr BBS01 should be fine. You can use a programming cable with these motors to tweak a bit more performance out of them, without compromising reliability.
April 28, 20187 yr Author Thanks for the reply’s- it sounds like the bbs01 is what I need. My average off road speed is roughly 10mph so high speed assist is not required. I just want to breeze up the hills. From what I’ve read I can use it without brake cutoffs if I don’t use a throttle?
April 28, 20187 yr From what I’ve read I can use it without brake cutoffs if I don’t use a throttle? you will need hydraulic brakes if you don't have brake cutoffs.
April 28, 20187 yr hi woosh what is controller amp rating for the 250w bafang, and can controller be replaced if you (fry it ) by going too slow up a steep hill) as I did last week on 350w rear hub with shunt mod. how does the bafang compare with your ready built rio mtb 60nm and 17 amp controller
April 28, 20187 yr Woosh - I see you also sell the GSM mid drive - which is better? the GSM is the only CD kit that can use an external controller so overheating is not an issue. The reason BBS01 and especially the high powered BBS02/HD may be more prone to overheating is because the controller is filled with latex like liquid rubber. There is no air circulation to cool it. the downside is it needs an external controller. A few customers run it with the KT S6, others with S9 and even S12. (the number of FETs).
April 28, 20187 yr hi woosh what is controller amp rating for the 250w bafang, and can controller be replaced if you (fry it ) by going too slow up a steep hill) as I did last week on 350w rear hub with shunt mod. how does the bafang compare with your ready built rio mtb 60nm and 17 amp controller All mid drives need to be in the right gear. I have stalled the GSM (once, very briefly) on a >15% hill when testing. I have since changed the chainring to a smaller one. The BBS01 has a 15 Amp controller that can be tweaked up to 18 A IIRC.
April 28, 20187 yr how does the bafang compare with your ready built rio mtb 60nm and 17 amp controller you do get about 10% more out of CD kits but you have to use the right gears. The CD will always beat geared hubs on the spread of speed and torque, on top of weight distribution. I like the 48V 18A SWX02 kit best, you have the torque of CD kits without having to think of gears.
April 28, 20187 yr Woosh - I see you also sell the GSM mid drive - which is better? The GSM is better because you can choose the controller for it. Both are almost identical in that chainring spiders for BBS0x fit the GSM too. The Bafang is better finished and you can buy alloy secondary reduction gear covers.
April 28, 20187 yr The Bafang is better finished and you can buy alloy secondary reduction gear covers. For the BBSxx series? Got a link for that?
April 28, 20187 yr Sure: http://precialps.com/uk/accessories-bafang-bbs01-bbs02/17-carter-de-protection-avec-joint-a-levre-bafang-bbs01-bbs02.html
April 28, 20187 yr what about this are they here in the uk http://www.cnebikes.com/product/250W-BAFANG-MAX-MID-MOTOR-KIT.html
April 28, 20187 yr what about this are they here in the uk http://www.cnebikes.com/product/250W-BAFANG-MAX-MID-MOTOR-KIT.html you need a special frame for it http://www.cnebikes.com/uploadfiles/103.224.250.119/webid92/source/201709/15043155992.jpg
April 28, 20187 yr For the BBSxx series? Got a link for that? that caught my eye as well, bet you`ve cracked the original cover tightening it up too.
April 28, 20187 yr that caught my eye as well, bet you`ve cracked the original cover tightening it up too. How'd you guess
April 28, 20187 yr you need a special frame for it... ...or bespoke boom for me and my recumbent trike.
April 28, 20187 yr Sure: http://precialps.com/uk/accessories-bafang-bbs01-bbs02/17-carter-de-protection-avec-joint-a-levre-bafang-bbs01-bbs02.html Ehhh??? Am I missing something here, no mention of it being alloy
April 28, 20187 yr You can have the best of both worlds by getting the 25 amp 36v 250w BBS01. It's basically a BBS02 with a special controller. It's legal and gives 66% more power than a standard BBS01. You can get them from Em3ev.com and some other resellers.
April 29, 20187 yr Ehhh??? Am I missing something here, no mention of it being alloy Precialps specialise in CNC aluminium. Careful it is for the second generation motors with 7 screws.
April 29, 20187 yr Author Can someone link to an external controller needed for the gsm motor. I’ve googled KT controller, but I’m unsure exactly what’s needed. Also I don’t want another box/bag on the bike so can the controller be battery integrated or handlebar display integrated? I like the idea of remaining road legal but maximising torque and power. So the gsm appeals from this perspective.
April 29, 20187 yr BMSBattery sell the 09 dolphin battery controller for integration with battery it comes as a kit with LCD and kit. 36 or 48v option. https://bmsbattery.com/controller/698-sine-wave-controller-for-09-case-controller.html DASKIT in Germany do a battery integrated combo unit as used in Oxydrive kits, though whether they sell direct is unknown. Other wise you have to use a box type controller.
April 29, 20187 yr Can someone link to an external controller needed for the gsm motor. I’ve googled KT controller, but I’m unsure exactly what’s needed. Also I don’t want another box/bag on the bike so can the controller be battery integrated or handlebar display integrated? I like the idea of remaining road legal but maximising torque and power. So the gsm appeals from this perspective. If you want to run it at 48v a controller out in the breeze would be my option. The motor seems to draw current differently from a hub motor, not more current, the same amount but probably ramping up more quickly. Some of the first testers had problems with weaker batteries and even I carved a huge chunk out of the useful life of my 10.4 Ah bottle battery. In any case the controller gets really hot. Just before last weeks "incident" I switched back to 36v and power is just fine at 15A x 36v compared to 15A x 48v but cadence is better at the latter. I think that for normal use I will go for 11A x 48v. That means using this controller: http://www.pswpower.com/peng/iview.asp?KeyID=dtpic-2016-3F-39N8.50CQE with a C5 setting of 04 on the LCD3. The one I am using now is here: https://bmsbattery.com/ebike-kit/695-s06sc-sine-wave-controller-for-central-motor-ebike-kit.html I only have nice things to say about how smooth it delivers the power. The only problem I have with it is that I spin too fast naturally and get back EMF at the most stupid moments, my problem not the controllers fault hence my move to 12S 44.4v.
