hi all I'm wondering if anyone has experienced the problem I'm having with my Bafang bbs02 kit ,i fitted this kit a few weeks ago and have been using it along with my Ping 36v 15ah lifepo4 batteries with no problems at all as these batteries are coming towards the end of there service life (4 years old)i decided to have a new bigger battery built which was a 17.5Ah Ncm pack when using it with the kit after about 4 miles with mid assist level the power level noticeably drops and the battery fully discharges after 6 miles, after sending the battery back twice the battery builder thinks the problem is with the kit as the cut off voltage is set at 31v on their controller as they are set up to use lifepo4 batteries therefore prematurely cutting the battery off .having carried out numerous tests all point to the battery fully discharging and not being cut off by the controller even using with a lower power kit with voltage cut off @ 27.5 v . i have never come across this and have always used bagang kits with different battery chemistries with no such problems has anyone experienced similar? any information appreciated
