I've just developed an issue on my trusty BBSHD. Basically when pedal assist kicks in (I didn't fit a throttle) , the cranks do not stop rotating unless the power is cut (e.g. braking or changing gear). Its as if I'm riding a fixed wheel bike with no freewheel - NOT GOOD!
I've tried turning it on and off, and am about to try and flash the controller again - but I worry it may be a mechanical problem. Pretty sure the chain ring did not go backwards if you try to back pedal the crank before - but it is now.
It's been a daily driver for the last few years so suggestions as to what might be the problem would be greatly appreciated.
Warm regards
Mark
Warm regards
Mark
